Message 11 of 12
Re: Using FTTP with an ASUS RT-AX82U router - the setup. How's it done?
Both Digital Voice and the hybrid connect rely on the SH2 and will not work with a third party router.
If you wish to use the Asus in conjunction with the SH2 in order to avail yourself of DV and hybrid connect, you will need to configure the Asus as a secondary router
Read from message287 onwards on this thread https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-with-different-Router/td-p/20...
Message 12 of 12
Thanks for info.I guess that is an option if it is not too complicated a procedure. Would mean i could still use the digiIal  landline  and avail of the hybrid connect..I surprised myself getting the Asus router working so quickly this morning. I will check out your link now.Thanks again.
