AJC1
Message 1 of 5
Using Fibre Equipment - just past end of Fibre Service
Hi there,
looking for some helpful advice??
My house is on a road which has Fibre at one end, however, we are just outside max distance from cabinet..
I have been told that if I would be able to use Fibre 'Equipment', that it will be much faster, just not potentially achieveing Infinity guaranteed speeds...
Does anyone have experience of this, and how would I go about getting it??
If not, going for Bluebox next week..
Thanks..
4 REPLIES 4
DavidM
Moderator
Moderator
Message 2 of 5
Re: Using Fibre Equipment - just past end of Fibre Service
Hi @AJC1 and welcome.
Can you enter your number into this checker and post the results? Please remove the number before posting.
Cheers
David
AJC1
Message 3 of 5
AJC1
Message 4 of 5
Thanks David,
please see attached..
Webby
Message 5 of 5
Seems you’re too far from the cabinet.
