Message 1 of 1
Using Google Nest Wifi - Removing HomeHub 5
Hello all,
I am looking to start using a Google Nest Wifi setup.
I am aware that my Home Hub does not allow bridge mode, so am looking to replace it with a normal VDSL modem.
I am looking at the BT Openreach Huawei EchoLife HG612.
I expect that this will be a suitable replacement as a modem, and then I can connect the Nest Wifi via RJ45.
I will then connect a switch to the Nest for more wired ports.
Is this correct. Is that the correct device to be using?
