Message 1 of 2
Using Hybrid Connect with Halo 3?...or do I need Halo 3+?
Hi. I have BT Fibre with Halo 3, a Smart Hub2 and 4 Complete WiFi discs. My system is working fine.
I do not have Halo 3+ but have just been offered a Hybrid Connect box by a friend which I would like to install 'just in case'. My question is: will the Hybrid Connect work on my system or do I need the '+' (ie Halo 3+) in order to use it?
Thanks.
1 REPLY 1
Message 2 of 2
Re: Using Hybrid Connect with Halo 3?...or do I need Halo 3+?
You will need to have Halo3+ and that will include a Hybrid box.
Buying or having a box as a gift is of no value.
