Message 21 of 44
Re: Using a Homehub 2.0
you could try the hh1 there is noting to lose
Message 22 of 44
From your stats you are now a lot further rom the exchange than you were before hence the far lower speed. Most router only show an attenuation of 63.5 but the true figure is far higher - the higher the attenuation the lower the expected connection speed. The test socket is behind the front pate of aster assuming nte5
John46 i think low downspeed of 576 is due to distance from exchange
Message 23 of 44
yes reviewing the post i agree just distance
Robbie_Macca
Message 24 of 44
HH1
DSL Connection
Link Information
Uptime:0 days, 0:03:07
Modulation:G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:288 / 192
Data Transferred (Sent/Received) [KB/KB]:53.00 / 47.00
Output Power (Up/Down) [dBm]:12.0 / 12.5
Line Attenuation (Up/Down) [dB]:31.5 / 63.5
SN Margin (Up/Down) [dB]:7.0 / 8.5
Vendor ID (Local/Remote):TMMB / TSTC
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):1 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):8 / 0
FEC Errors (Up/Down):0 / 0
CRC Errors (Up/Down):0 / 0
HEC Errors (Up/Down):0 / 0
Line Profile:Interleaved
Message 25 of 44
The stats are even lower. Was that from test socket?
Robbie_Macca
Message 26 of 44
The stats provided are with it connected into the test socket.
I take it upgrading to the latest home hub is gonna have nominal impact on speeds?
Robbie_Macca
Message 27 of 44
yes, but last stats are with HomeHub 1
Message 28 of 44
Yes that's what i meant the hh1 stats are wore than the hh2 and they were low - were hh2 stats from test socket?
Robbie_Macca
Message 29 of 44
yes both from test socket?
are the speeds dimishing as we speak though because of all the swapping around?
what should i do as a next step, blog in the hh2 into the master socket and leave for 10 days?
Message 30 of 44
Connect hh2 to test socket an post back in 3 days with current stats
