Robbie_Macca
Message 31 of 44
Re: Using a Homehub 2.0
ok thanks
Robbie_Macca
Message 32 of 44
Left it plugged in for 3 days and this is the stats
Speed test is constantly 0.6mb when ive checked throughout the 3 days, so im not convinced that BT are trying the different speeds thing to train the line etc... any ideas?
ADSL line status
Connection information
Line stateConnected
Connection time2 days, 21:32:36
Downstream704 Kbps
Upstream288 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)7.7 dB / 7.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)14.6 dBm / 12.3 dBm
Loss of Framing (Local)0
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)829666 / 0
CRC Errors (Down/Up)4754 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)2668
Message 33 of 44
Stats better than before but still only .7mb connection speed. What speed does this give https://www.btwholesale.com/includes/adsl/main.html
Robbie_Macca
Message 34 of 44
Available ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Featured Products
WBC ADSL 2+Up to 11--6.5 to 19Available
ADSL MaxUp to 6--5 to 7Available
WBC Fixed Rate0.5 ----Available
Message 35 of 44
That is so inconsistent with your router stats - checker shows about 6mb but with your 63.5+ attenuation you are never going to get anywhere near that. Have you any idea how far you are from the exchange?
Robbie_Macca
Message 36 of 44
i think about 4km as the crow flies.
Have only just moved to property, and got the new number.... wondering if the inconsistency is because the details from previous post are for where our new number was previously located?
its as if the speed is capped as the graph on the app flatlines pretty much straight away, where as where i was living before it would be jumping around all the time.
Message 37 of 44
That would explain the inconsistency between stats and checker
Robbie_Macca
Message 38 of 44
BT estimated between 1.5 and 3 before we moved
is there anything that can be done to trigger the system to start trying quicker speeds?
Message 39 of 44
with that straight line distance and the route many lines take your attenuation is likely to be 63dB + so the speed could as low as you are seeing
Message 40 of 44
With your attenuation of 63.5db that is max router hows but your true figure could be significantly higher - hence why low speed. You cant make line go faster as noise margin about normal leaving little scope
