Newbie
Message 1 of 6
Using a different router/modem with infinity
If I were to use a different VDSL modem/router with my infinity (like netgear or similar), would this prevent the broadcast of the BT zone/wifi with FON signal from my router whilst still allowing me to not officially opt outof the service (and therefore continue to enjoy the benfits of it?)
5 REPLIES 5
Message 2 of 6
Re: Using a different router/modem with infinity
Message 3 of 6
yes you can however BT WiFi does not affect your connection as you always get priority of your connection and actual connection speed
Newbie
Message 4 of 6
Excellent, thanks.
Just wondering as I do not live somewhere it would be of benefit to anyone and I do not like the idea of my devices connecting to the Home hub via FON rather than my own connection, just seems a bit of faff.
Thanks.
Message 5 of 6
You do not need to connect via BTWifi. You would connect to your private network being transmitted by the Homehub.
BTWifi is a separate public network transmitted by the Homehub.
Distinguished Guru
Distinguished Guru
Message 6 of 6
gg's right. If you're otherwise content with the home hub, setting up a new router would be an unnecessary faff as well as being a waste of money.
