serbusfish
Message 1 of 5
Using alternative router with Home Hub 5
Im am wanting to set up my TP LINK TD-W8960N as a router while using the HH5 as the modem. I have been sent a guide from TP Link so I know how to set up the connection but it needs a username and password to connect to the BT service. How do I find this out? Ive looked through my home hub settings but all I can find is bthomehub@btbroadband.com, surely I need a more personalised login?
4 REPLIES 4
imjolly
Message 2 of 5
Re: Using alternative router with Home Hub 5
the login in the hub is same for all - authenticaion is your phone number
Keith_Beddoe
Message 3 of 5
The HH5 cannot be used as a standalone modem. You would have to obtain a separate modem.
I am assuming that you have an Infinity connection.
serbusfish
Message 4 of 5
Oh, I was told I could use the Home Hub as the modem by TP Link.
If thats the case im not sure what to do, the TP Link isnt very old and I dont really want to buy another router, but I guess I will have to.
Yes it is an Infinity connection. The actual home hub is fine, the only problem I have is that you cannot open the same port/s for multiple devices, and as I have a number of gaming consoles this is a major problem.
My PS4 is setup fine, but I the Xbox One shares many of the same ports and currently has a strick NAT and 150ms ping because I cant open ports for it.
gg30340
Message 5 of 5
You could buy an Openreach modem for about £20 from an auction site and use that instead of the HH5 and connected your TP-Link to the modem by WAN port.
