Message 1 of 4
Using an aftermarket router on 900/110
I'm not well versed in networking; do I need to connect my router in PPPoE mode or will DHCP work? I will not be using the Smarthub 2.
Tags (2)
3 REPLIES 3
Message 2 of 4
Re: Using an aftermarket router on 900/110
PPPoE
username [email protected]
password bt
Message 3 of 4
@licquorice
A few quick questions, sorry. I've read online that PPPoE adds massive overhead, and if your router does not have a hardware offloading option, it shouldn't be used with gigabit speeds. Is there a reason as to why PPPoE is recommended? Is it the only option available because BT wouldn't support any other protocols on aftermarket routers?
Message 4 of 4
It is the protocol BT use, there is no choice in the matter.
