nigelangel1
Message 1 of 17
Using and external hard drive with Home Hub 3
I have the home hub 3, and have fitted my external hard drive to the USB port. Before I did this I formatted the drive to FAT32, and it does show up as an external drive in the Home Hub list of connected items.  My only problem is, none of the my connected computers can neither see the drive or access it.
I'd like to hear from anyone who's managed to get an external hard drive working while connected to the Home Hub 3, and if that's you, please, please tell me how you did it!!! The drive is definitely formatted to FAT32.
16 REPLIES 16
Sage
Message 2 of 17
Re: Using and external hard drive with Home Hub 3
You will need to map the drive. See here for instructions
nigelangel1
Message 3 of 17
Thank you so much,  I've been trying to do this since I changed over to BT Infinity!  I've done exactly as suggested in the link, and it works great.
All this time, I simply needed to ask how to do it via the forum! Smiley Very Happy
andystones
Newbie
Message 4 of 17
Can you do this on a mac? (osx 10.7 Lion)
vipermo
Message 5 of 17
andystones  did you find out mate hope to get this working on mac?
amacfx
Message 6 of 17
Any luck getting this hooked up so that Macs can use a networked drive.
I've formatted a drive as FAT and it will mount ok (I can see it on my different Macs - all running 10.7) but can't actually connect to any of them - always getting the following error message :
The operation can’t be completed because the original item for “USB_Disk” can’t be found.
If you found a working solution I'd really appreciate you posting here.
Cheers.
asl1956
Newbie
Message 7 of 17
I have managed to connect to an external HDD plugged into the HH3 via the USB connector.
1. On the MAC go ingto Finder and select "GO" from the menu.
2. In server address type smb//bthomehub
3. Click "Connect"
You will then connect to the HH3 and should see USB1 listed as a folder.  If you click this you will be connected to the drive.
You can automate connecting by selecting "+" in the Connect to Server dialogue box.  You then need to go to users in System Preferences to connect automatically on log in.
You'll find the process here http://support.apple.com/kb/HT4011
asl1956
Newbie
Message 8 of 17
2. In server address type smb://bthomehub
3. Click "Connect"
dcullum
Message 9 of 17
This works fine for me too!
onizuka1957
Newbie
Message 10 of 17
Hi, sorry to bother you but you seem as though you may be able to help.  I have plugged in devices into the USB port on my Home Hub 3, it reports no devices connected.  I have raised a complaint with BT only to be told that they do not support the port.  Despite help pages state otherwise, raising a complaint they contacted me today to say the same.  So there own help page and instructions are a lie.  The did finish by saying that I can pay to have it enabled I have to pay, weird seeing the only router (hub) I can use is the one supplied by BT.  Why is it you and others have yours enabled yet mine is not, unless I pay for it.
