Rockintone
Message 1 of 7
Using existing BT Vision Box to view pre-recorded programmes
Hi all,
Maybe one for the Mods but here goes:-
I have just upgraded to Youview and the box will arrive next week (or so I am told).  I currently have a black bt vision box and my wife has loads of recordings still to watch.   My question is this, when the Youview box arrives and I connect it up to the internet (and hence disconnect the old btvision box) will the old btvsion box still allow me to watch any recordings that are on it?  I am sure I have read somewhere that once the bt vision box is switched off and rebooted without a connection to the internet you looose all functionality.
Any help/assistance would be appreciated.
6 REPLIES 6
walkerx
Recognised Expert
Message 2 of 7
Re: Using existing BT Vision Box to view pre-recorded programmes
@Rockintone wrote:
Hi all,
It depends on what software is on it - you could set the box up in another room and have it connected to internet and it may still work fully for you, but this is not guaranteed
TimSmedley
Message 3 of 7
Hi, we moved from the black vision box to YouView just before Christmas.
Both boxes are working with full functionality on both; we did not loose the recordings.
Tim
Rockintone
Message 4 of 7
Thanks for the replies,
Just to be clear I do not intend to connect the BT Vision box to the internet once my Youview box arrives. Anyone tried to see if a btvision box will still allow you to watch any pre recorded stuff on it without an internet connection?
easybreeze
Message 5 of 7
Try it now... Unplug the lan cable, this will stop it talking to the internet and put you in the same position.
I can't imagine it will stop working but then why do BT state that it will?
TimSmedley
Message 6 of 7
When the YouView box arrived I was a good boy at first and didn't use the Black Vision Box at all; however with three home from Uni demand to tempt fate was great so we started it off without the BB connection. It had a hissy fit and would not work so after ~10 minutes gave up and put in the network cable and it started. If you play around with it and have more patience than me you might do better.
I do recall that the EPG comes down the broadband so certainly that functionality will go id there is no connection.
Tim
WhyWhy
Message 7 of 7
Hi
Did you ever manage to watch your recordings on your old box? I'm in same situation, new box works well, but old box says "looking for network"....all I want to do is watch old recordings, before sending back the box...
D
