Message 1 of 3
Using fon hotspots abroad
I got BT Wifi as an extra with my broadband package. It claims that you can use fon hotspots abroad by logging in with BT/ in front of your login name. When I try that I get the message "You're not eligible for access to Fon hotspots while you're abroad". Why not?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Using fon hotspots abroad
Hi @CreenW,
If you take a look at - Can I use BT Wi-fi abroad?
If after trying that and you're still having issues, can you check to make sure that you are still opted into BT Wifi - How do I join BT Wi-fi?
Give that a go and let me know how you get on?
PaddyB
Message 3 of 3
