Message 1 of 5
Using own Router, which modem should I get?
I bought a third party router the other week to use the qos features to improve my gaming experience. I knew I needed to buy a modem so I got an second hand BT Openreach modem plugged it all in and I got a WIFI signal but  I couldn't get a internet  connection. Plugging a ethernet port from my pc to the second slot on the modem I still didn't get a connection.
I would like to know what modem I should buy that works with BT.
(I bought a NetDuma router, I have Normal BT fibre at 70mbps down, 20 up)
The main problem in trying to solve is gaming while people are streaming. Games such as FIFA require a constantly low ping however when someone is streaming every 5-10 seconds it goes to 100+ ping for 2-3 seconds.
4 REPLIES 4
Message 2 of 5
Re: Using own Router, which modem should I get?
If you have fibre2 rather than G.Fast, the Openreach modem should have been fine. It should be plug and play, perhaps it was faulty.
Message 3 of 5
when you connected your 3rd party router did you enter the username and password
bthomehub@btbroadband.com
password if needed - anything many just use BT
Message 4 of 5
Message 5 of 5
Yes I did that.
