Luapmac
Message 1 of 12
Using powerline adapter for extra channels.
Hi, I have read that I will not be able to view the 'extra' channels via powerline adapters. I get 70mbs on mine. Can anyone confirm if indeed you must be connected via Ethernet cable or is anyone actually using adapters to get the extra channels. thanks.
11 REPLIES 11
bawmer
Message 2 of 12
Re: Using powerline adapter for extra channels.
Providing you have a good connection they can work fine - mine do as do many others who have reported on this forum.. BT will not support them though as any problems are likely to be outside of their domain.
Luapmac
Message 3 of 12
Thanks, thought that they would work at the speeds I get.
stuartrogerson
Distinguished Guru
Message 4 of 12
Works just fine for me and I have a much lower speed
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Luapmac
Message 5 of 12
Thanks for your help, and comments
AA99
Message 6 of 12
I started a post somewhere last month but can't find it now. Had new YouView box and Hub 5 installed. Engineer said no need to install ethernet cable to box from main BT point and hub in upstairs bedroom as powerline adaptors would work for extra channels and BT Sport. I have never been able to pick them up though on a scan and even trailed the ethernet cable through the house and tried scanning but nothing?! Any ideas? Thanks
stuartrogerson
Distinguished Guru
Message 7 of 12
Have you actually subscribed to the channels?
Helpful Post?
AA99
Message 8 of 12
What exactly does that mean?  I only have tv essential but was told with the new infinity broadband package, I would be able to get BT Sport on tv for free plus extra channels?
stuartrogerson
Distinguished Guru
Message 9 of 12
With TV essential you will have access to no extra channels unless you subscribe to them.
If you want access to BT Sport then you must ask as I understand it for it to be activated,
You must also have a multicast enabled cabinet/exchange
Helpful Post?
JohnX
Message 10 of 12
I get frequent picture break-up when recording the extra channels. My YouView box is connected via PowerLine adapters.
The problem, though, is intermittent, so some recordings are perfect, others unwatchable.
Anyone else using PowerLine adapters experiencing this problem?
The PL adapters I'm using are TP Lingk 500mbit ones. I have no problems with on demand playback.
