chrisbu
Message 1 of 18
VC011 Error code on BT Sport App Android
Anyone else getting the VC011 error since updating to the latest version?
Worked fine before the update but not now 😞
Android 5.1 Lollypop
Oukitel U8 Universal tap
17 REPLIES 17
rarmitage124
Recognised Expert
Message 2 of 18
Re: VC011 Error code on BT Sport App Android
Have you tried looking at the BT sport app support pages? For your error code you need to do this:
Refresh the page and try again
Log out of the app and back in again
If this doesn't work, you could try clearing the app's data and cache.
Error VC011 may also occur if you use data compression apps.
If you have already looked or tried them all post back and we will sew what we can do
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
andysmedley
Message 3 of 18
Same problem. Worked OK last week now vc011 error. Annoying.
rarmitage124
Recognised Expert
Message 4 of 18
I think the only thing you can do is report to developer and see if BT notice.
Paul1360
Expert
Message 5 of 18
Yo,
Not been around much but yesterday this error popped up and no matter what I try nope still the same as the other customers.
Gone through all the steps to resolve this error, removed and did a fresh install but nothing helps. So if anybody has any info on how to fix this error I'll be more than happy.
iechyd da
newapollo
Message 6 of 18
I have 4 devices, all with version 2.9.1 of the BT Sports App.
I think the problem may relate to the size of the device.
It works fine on my mobile, a Galaxy S3, android version 4.3
It also works fine on my 7 inch tablet running android version 5.1.1
I have 2 android tablets with 10 inch screens, running android versions 4.4.2 and 5.1.1,  and I receive the same error message VC011
I have followed the help solutions without success, having refreshed the page and tried again
Logged out of the app and back in again
I have allso cleared the app's data and cache.
I do not use any data compression apps.
I have uninstalled and reinstalled current version.
I have also downloaded an older version of the app, 2.8, however it made me perform a forced update to the newer version with the same result error VC011.
esrxd57
Message 7 of 18
Re error code VC011 on latest update of BT Sport App , BT are aware of issue and currently working on solution. BT advise new update wil be released when available
Paul1360
Expert
Message 8 of 18
newapollo,
I don't think it has anything to do with device size as I've got 7", 10" and bigger Tabs that work and I've done all the steps that BT say will fix this bug on a new Tab but sadly it does not.
I spoke to tech team yesterday and as has been posted they know about it and are working on a fix.
maddo
Message 9 of 18
I bought a new adroid 5.1 tablet on 23rd. Nov. BT sport has never worked on . I get one of two error codes up  -- DT001 or the VC 011 when I click on 'watch now'. Hope result comes before time runs out to return tablet as useless
chrisbu
Message 10 of 18
There's now a fix (kind of) until it's sorted in future release. If you are experiencing the erroVC011 on your android then give this a go:
Download the BT Sport app if you've removed it
Go to
https://play.google.com/apps/testing/com.bt.btsport and sign up for tester
An update will become available - Update the app and retry
Hope this helps
