Thompson218
Message 1 of 22
VDSL Range B (Impacted)
Its poorly at the moment but even when well my download speed was only ever just above the Range B impacted speed. My house wiring many years ago was simplified and there is only one telephone socket now, wired in by BT. I have no taps (as mentioned in the blurb) as far as I know.
So is there anything i can do to improve things?
Thanks.
21 REPLIES 21
Webby
Message 2 of 22
Re: VDSL Range B (Impacted)
Have you had an engineer visit?
Thompson218
Message 3 of 22
No I've been told its a problem in the area, feel as though I'm being fobbed off. Getting 15Mbps at the moment on Infinity2. Image below refers.Capture Troubleshooter 2118 on 31102016.JPG
licquorice
Message 4 of 22
Download speed or sync speed?
gg30340
Message 5 of 22
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then scroll down the page and carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
If you have a Homehub 5 can you post the stats from 1-12 by logging onto the Homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
or
If you have the Smart Hub, (Homehub 6) can you go to hub manager then advanced then technical log and post the stats. http://bthomehub.home/
Thompson218
Message 6 of 22
As requested.
FYI The hub has been manually restarted because I bought a new cable home from work to try. Other than that it has been left on for 3 or 4 days since the last enforced disconnect - I had to move it while decorating!
Its been in the 20's or lower for days now, 15 Mbps yesterday. The best speed I have ever had is 42Mbps hence my question about why I might be impacted. Its sitting at high 20's at the moment as you can see.
information for helpdesk agents 1758 02112016.JPGBT Broadband availability checker 1755 on 02112016.pngbt wholesale speedtest 1734 on 02112016.JPG
gg30340
Message 7 of 22
Can you re-run the tests and re-post the results with the Homehub connected to the test socket in the master socket.
Thompson218
Message 8 of 22
Is that the one I get to by removing the front panel?
Do I need a filter?
Thompson218
Message 9 of 22
My socket looks like this only with MK2 in the top right hand corner.
bt socket.jpg||
Webby
Message 10 of 22
Yeah you'll need to remove the face plate and use a filter.
Was your speedtest done wired or wirelessly?
