gg30340
Message 11 of 22
Re: VDSL Range B (Impacted)
Remove lower plate and use a filter.
Thompson218
Message 12 of 22
Wired, and with WiFi disabled at the hub. My laptop was the only device connected.
Thompson218
Message 13 of 22
Ummmm, a filter!!
Thompson218
Message 14 of 22
Can't locate a filter, I'll see if I can get one tomorrow and post back on this thread.
Thanks for the help.
Webby
Message 15 of 22
No problem
Thompson218
Message 16 of 22
ok, here goes. I ran several tests through the test socket. The first was a scary 3mbps so I reran as below.
Helpdesk data
I reran the speed test through the normal soxket and got simular speeds to above, but posted below FYI.
So as you can see my speed has dropped from previous figures to 15Mbps or thereabouts.
pippincp
Message 17 of 22
Have you tried a quiet line test? 17070 option 2.
Webby
Message 18 of 22
Very strange that you sync at the very same value in the test socket!
Looks like you need an engineer visit (if your line is quiet).
Thompson218
Message 19 of 22
Yes, done the quiet line test and its quiet.
How do i go about booking a visit?
Webby
Message 20 of 22
Call the technical helpdesk and raise a fault/request one as your line is connecting below the minimum expected speed.
