With the new BT TV packages, particularly the VIP package do you get any kids channels ?
Solved! Go to Solution.
Hi @smc78, thanks for posting. No, the kids channels aren't included but you can add them as a bolt-on. Check out the Now TV flexible packages FAQ's post for more info.
@NeilOwrote:Hi @smc78, thanks for posting. No, the kids channels aren't included but you can add them as a bolt-on. Check out the Now TV flexible packages FAQ's post for more info.
Thank you, have had a look at that.
Can I just check, there is BT TV Kids and Now TV Kids, you can choose either, is that right?
@smc78 yes you can choose either one or both if you wish.
@NeilOwrote:
Just for clarity, Is the sport package available on it's own at £15/ month or is the entertainment package a mandatory base for adding the other packages to, i.e. the sport package would then cost the sum of £10 + £15 per month (as with Sky packages)
Hi @smc78, yes you can log in to the Amazon prime video app on the box with your current subscription details.
@Anonymous thanks for posting, you can have the £15 Sport package on its own, there's no need to have entertainment as well.
