Robyroy
Message 1 of 10
VPN Connection from Home Hub 3
Can anyone help? I have recently changed to a BT Home Hub 3 having successfully used a Netgear router for many years.  I changed to get better wireless connectivity at home.  However, i can no longer connect to our office server through a VPN connection.  I used to connect over IPSec and it worked fine with the Netgear router but HH3 just won't accept the connection.
I know from the forum that there are settings in the HH3 which probably need to be changed and if anyone can guide me through those, it would be appreciated  I have an Apple Mac at home (not that that should make any difference) and a standard Broadband connection (ie not Infinity).
Many thanks.
Robroy
9 REPLIES 9
Message 2 of 10
Re: VPN Connection from Home Hub 3
hi enter the hub manager on the HH 3 then click on a to z
scroll down and you will see VPN click on it then you can set up from there
Robyroy
Message 3 of 10
John,
Thank you for the information.  I changed the setting but unfortunately it made no difference.  The connection was just rejected when i tried to make it.  Any other thoughts?
Robyroy
Message 4 of 10
sorry no normally that works for VPN's all i can suggest is retry your netgear
Robyroy
Message 5 of 10
I re-connected earlier so that I could access the office and the netgear is no problem at all.  I just don't get great coverage in my house.
Thanks for your help, all the same.
Message 6 of 10
hi this link may help you with your wireless issues http://www.cbeddoe.btinternet.co.uk/wireless/wireless_boost.html
Robyroy
Message 7 of 10
Thank you.  I had seen that a link to that before and had thought about it as an option.  By the way on IPSec, the recent that it cannot connect is because of a 'Network Collision' in case that means anything at all.
Message 8 of 10
a Google search explains Network collisions to save trying to explain here
Robyroy
Message 9 of 10
Problem solved! I changed the DHCP range on my HH3 (to the alternative supplied by BT) and that has removed the problem.  So I can now connect directly to my office using the HH3, wiht the improved range.
Message 10 of 10
Hi glad you have now sorted the problem post back any time for any help
