Message 11 of 15
Re: VPN (and now internet) won't work after switch to Windows 10
Hi Licquorice - I wonder what has changed ? Before I upgraded to W10 I had the parental controls on, and I could use the VPN fine. I never had a problem with DNS etc.
What has W10 changed that now stops me using the vpn - what settings do I need to tweak (I assume on the PC, not the HH)  to get back to the settings that my pre-upgrade PC had which allowed me to maintain parental controls and use the vpn ?
Thanks again
Message 12 of 15
Hi - I've had another thought. I originally installed the Cyberghost vpn software about 18 months ago, using Windows 8.1, and I don't recall having any issues with DNS etc and it all worked smoothly. I wonder if I uninstalled & reinstalled Cyberghost, would it configure itself to work with Windows 10, apply the necessary appropriate DNS settings itself ?
Cheers
Message 13 of 15
Having neither W10 or a VPN I'm not sure what else I can suggest. Has the upgrade made any changes to your VPN settings?
Message 14 of 15
Posts crossed. Yes, might be worth re-installing cyberghost
Message 15 of 15
Hi Licquorice - I've removed / reinstalled Cyberghost but it will not allow me to choose a server outside of the UK. I assume this is due to the BT parental controls so I have asked BT for the PIN to enable me to switch off the controls (temporarily). I will try to install Cyberghost without parental controls in place and if the VPN works, I will then try to reintroduce the parental controls to see if Cyberghost will still work after that.
As mentioned, when I originally installed Cyberghost, alongside the BT parental controls, I had no problems at all connecting via the VPN, so I am bemused the update to W10 is causing such issues.
Many thanks for your help.
Scooby99
