Message 1 of 10
Very Slow Broadband Download Rate from 7mps to 50kbps Please Assist
Hello everyone, last week my BT Phone and Internet was down and it was fixed on thursday. My phone line works but I noticed my download rate has dropped from 7mbps to 50kbps ever since its fault.
Alhtough early this my download rate dropped from 7mbps to 1mbps but I did not mind besides am always away from home due to my nature of my job, once I experience drop in downloads speed I just do a reset and it picks up but after the fault was fixed its 50kbps dead on.
I used earthernet networkcable plugged in to my PC from my BT Hub3 same results. Please Admin and tech geeks in the forum I need your assistance, here is the ADL Line status TEST below:
 ADSL Line Status
Connection Information
Line state:    Connected
Connection time:    0 days, 01:50:13
Downstream:    576 Kbps
Upstream:    1.098 Mbps
ADSL Settings
VPI/VCI:    0/38
Type:    PPPoA
Modulation:    G.992.5 Annex A
Latency type:    Interleaved
Noise margin (Down/Up):    22.6 dB / 6.7 dB
Line attenuation (Down/Up):    35.6 dB / 20.3 dB
Output power (Down/Up):    17.5 dBm / 12.8 dBm
FEC Events (Down/Up):    0 / 7
CRC Events (Down/Up):    0 / 1
Loss of Framing (Local/Remote):    0 / 0
Loss of Signal (Local/Remote):    0 / 0
Loss of Power (Local/Remote):    0 / 0
HEC Events (Down/Up):    0 / 2
Error Seconds (Local/Remote):    0 / 1
Also BTSpeed Tester result
1. Best Effort Test: -provides background information.
     Download  Speed
     0.48 Mbps
0 Mbps    0.5 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.48 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.5 Mbps.
 IP Profile for your line is - 0.51 Mbps
2. Upstream Test: -provides background information.
     Upload Speed
     0.83 Mbps
0 Mbps    0.83 Mbps
Upload speed achieved during the test was - 0.83Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
I dialled 1470 17070 and my phone line was quiet, How do I slove this or increase my download rate of 50kbp to 7mbps that was promised by BT?
9 REPLIES 9
Message 2 of 10
Re: Very Slow Broadband Download Rate from 7mps to 50kbps Please Assist
All the resets/drops in connection have resulted in your line ending up in a banded profile. You need to stay connected 24/7 for 3/5 days with no resets and the banding should release automatically with noise margin dropping to 12/15db and speed increasing. Noise margin should continue to fall probably 3db at a time with speed increases until it get back to normal 6db
This may take a few weeks to get to 6db
Message 3 of 10
Okay, will do that and update you with results after 3-5 days later.
Message 4 of 10
No problem. There is always someone around to help
Message 5 of 10
This morning I noticed my BThub Broadband light flashing on its own and I decided to check if there any changes to my
ADSL Line status, its seems my downstream has increased and the Noise margin has decreased also. Does this mean its permanently fixed?
Althought I noticed my browsing speed has greatly increased, its just 24hours I will wait till weekend and have a ADSL Line test again.
Todays test 05/08/2013
ADSL Line Status
Connection time: 0 days, 00:45:00
Downstream: 5.556 Mbps
Upstream: 1.032 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 15.0 dB / 6.0 dB
Line attenuation (Down/Up): 35.4 dB / 20.3 dB
Output power (Down/Up): 20.5 dBm / 12.7 dBm
FEC Events (Down/Up): 162 / 0
CRC Events (Down/Up): 1 / 0
HEC Events (Down/Up): 0 / 0
Error Seconds (Local/Remote): 5 / 30
    Download  Speed
    5.09 Mbps
0 Mbps    7.15 Mbps
 Download speedachieved during the test was - 5.09 Mbps
 For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
 IP Profile for your line is - 5.02 Mbps
    Upload Speed
    0.83 Mbps
0 Mbps    0.83 Mbps
Message 6 of 10
you are out the banding so now need to stay connected 24/7 and noise margin will reduce probably 3db at a time with corresponding increases in speed until noise margin gets back to normal 6db  this may take a few weeks
Message 7 of 10
Just an update from the last time I was here.....
    Download  Speed
    6.85 Mbps
0 Mbps    7.15 Mbps
 Download speedachieved during the test was - 6.85 Mbps
 IP Profile for your line is - 6.6 Mbps
    Upload Speed
    0.85 Mbps
0 Mbps    0.83 Mbps
Upload speed achieved during the test was - 0.85Mbps
ADSL Line Status
Connection time:    0 days, 00:26:05
Downstream:    7.305 Mbps
Upstream:    1.066 Mbps
ADSL Settings
VPI/VCI:    0/38
Type:    PPPoA
Latency type:    Fast
Noise margin (Down/Up):    9.2 dB / 6.3 dB
Line attenuation (Down/Up):    35.3 dB / 20.2 dB
Output power (Down/Up):    20.5 dBm / 12.0 dBm
FEC Events (Down/Up):    0 / 0
CRC Events (Down/Up):    13 / 32
HEC Events (Down/Up):    28 / 7
Error Seconds (Local/Remote):    13 / 0
Its better but am still not happy with my download rate hardly get 1mb which is quite diasspointing, please BT Geeks/ Eperts in the forum how do I increase the download speed to 17mb BT Promised!
Recognised Expert
Message 8 of 10
Use this link to calculate your maximum speed http://www.kitz.co.uk/adsl/max_speed_calc.php
You will be a tad disappointed - sorry.
Message 9 of 10
given time your noise margin will drop again to 6db with a further increase in speed with your attenuation and a 6db noise margin i would expect at best with a perfect line around 11mb  just leave the connection  to finish  stabilising now
Message 10 of 10
you have a 6.8mb download speed at the moment that will improve as your connection speed improves
