Message 1 of 6
Very Slow Download and Upload Speeds
Hi,
A couple days ago my phone line dropped out, and our broadband download speeds went from around 49 mbps to not topping 4 mbps, whilst upload speeds dropped from 10Mbps to under 1Mbps. I have a Hub 6, and not had this problem before and since the phone line is now back working, yet the broadband speeds remain painfully slow.
Is there anything I can do to boost them back to what they were?
5 REPLIES 5
Message 2 of 6
Re: Very Slow Download and Upload Speeds
can you post hub stats  advanced settings then technical log information
enter your phone number and post results https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 3 of 6
Product name:
BT Hub 6A
Serial number:
+084319+NQ62353091
Firmware version:
SG4B1000E020
Firmware updated:
24-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 1 Hours 37 Minutes 2 Seconds
Data rate:
799 kbps / 4.20 Mbps
Maximum data rate:
15297 / 21162
Noise margin:
22.5 dB / 28.4 dB
Line attenuation:
32.9 dB
Signal attenuation:
15 dB / 32.9 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
71 MB Uploaded / 440 MB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-3WM5-2.4
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-3WM5-5
5 GHz wireless channel:
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:24:10:15
Software variant:
Boot loader:
7.33.1
Message 4 of 6
Do you have a dial tone?  If so try dial 17070 option 2 your should hear your number and then should be silent. Any noise is a problem
Message 5 of 6
Yes there is a dial tone, and the silent test is completely silent
Message 6 of 6
I would try test socket with a filter and see if that improves speed or just the same. If no change then you need to phone 151 and get engineer visit
