Xtrato
Message 1 of 10
Very Slow connection
I'm having some trouble having any usable access to the internet.
I have changed filters, plugged into the master socket and am using the BT HomeHub 2.
I'm getting around 100kbps and i usually get about 1.5Mbps. Looking at the router stats it shows the following.
Connection time 0 days, 02:54:52
FEC Errors (Down/Up) 11869 / 586
CRC Errors (Down/Up) 3571 / 297
HEC Errors (Down/Up) 39530 / 250
Error Seconds (Local/Remote) 11646 / 685
Is this amount of errors a lot for only 3 hours worth of time? Also, does this indicate a problem on the external network outside my home or could this be caused by an internal problem also?
9 REPLIES 9
Message 2 of 10
Re: Very Slow connection
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 10
If possible you should connect to the test socket and then post a full set of adsl stats. You should also run tspeedtester diagntic test and post results
Try quit line test. Dial 17070 option 2 should hear nothing and best with corded phone. If cordless dull hum is normal
Xtrato
Message 4 of 10
Thanks for the reply. Here is my full ADSL Line status:
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 03:22:04
Downstream672 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)11.6 dB / 14.0 dB
Line attenuation (Down/Up)66.3 dB / 31.5 dB
Output power (Down/Up)1.2 dBm / 1.2 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)11869 / 586
CRC Errors (Down/Up)3571 / 297
HEC Errors (Down/Up)39530 / 250
Error Seconds (Local/Remote)11646 / 685
Message 5 of 10
providing you maintain 3 days+ stable connection then post back your adsl stats we can then get your noise margin reset which will increase your speed
Xtrato
Message 6 of 10
Thanks for the reply. My quiet line test i cant hear anything. No cracking or anything. Unfortunatly i cant run a speed test. I get the following error:
This may be due to a problem with the speed tester, or your line may be running very slowly.
Doing a speed test from other sites it shows i get around 100kbps however. Normally i get around 1.5mbps
Message 7 of 10
Can you connect to test socket? You have a lo of errors for only a short time connected and if oise margin was lowr then errors would be even higher
Message 8 of 10
just maintain the stable connection then post back in 3 days with new stats and we can then get you further help
Xtrato
Message 9 of 10
Those results are with it connected to the test socket.
Message 10 of 10
The errors are very high and will get worse. Have you used a new filter? Do you use a phone extension cable as hey can cause problems?
