Message 1 of 4
Very high FEC errors
122,000 FEC errors in 9 hours, are FEC errors good apparently they are infact error correcters, I pulled stats from the hg612 modem and I've only had 25 CRC errors in that time, delay is on 8 though 😞 all them stupid home hub 5 disconnections are the cause, it's been rock solid in the 9 hours I've had the hg612 modem in. Noise margin is still below 6bB though
3 REPLIES 3
Message 2 of 4
Re: Very high FEC errors
FEC errors show that interleaving is doing it's job correcting errors and are ok
Distinguished Guru
Message 3 of 4
FEC errors show that there is noise on the line causing packet loss which has to be corrected by the modem or retransmitted.
If not, I'll try again 🙂
Message 4 of 4
Thanks for the help guys, in 9 hours there were only 25 CRC errors that was about til 2am and then when I woke up there were 2962 that was in a space of 21 hours, odd thing is the modem had reported it resynced but the router didn't resync which leaves me confused because if the modem lost connection so would the hub. It resynced at approx 6am and within those 5 hours from then til about 11-11 15 there has been 259 CRC errors. If what you guys are saying is that FEC is to do with noise does that mean that the lines faulty or the extension is faulty because bt told me the phoneline is fine but the modem and hub are connected to the extension. In the master socket there are only 2 wires connected to the extension those are blue and white. The wires for terminal 2 and 5 are disconnected. Thanks
