Message 1 of 1
Very odd Home Hub 5 behaviour
Discovered the internet was not available this morning.
Went to BT home hub manager and tried to reconnect was asked for my password which was rejected.
HH 5 had a steady orange light.
I restarted the HH 5 with the button on top of the device.
HH 5 connected then dropped the connection and then reconnected at 55000 kbps as normal, now steady.
Went to the event log (password now accepted) Noticed that no events were logged from around 16:30 on the 22nd Aug. until reconnection this morning 25th Aug. at 08:22.
I have used the internet on numerous occasions between these dates.
I have not encountered anything like this before. My password was entered correctly.
I believe the internet went down at approx. 11:30 last night 24th Aug.
So Iam concerned that my password was not accepted by the hub and the absence of data in the event log.
Any help on understanding this will be much appreciated
My computers are a MacBook Pro. and an iMac.
Part of the log showing missing dates:-
08:23:05, 25 Aug. DHCP Lease issued 192.168.1.223 to 38:c9:86:21:00:35 TerryCoillsiMac, lease duration is 86400 seconds
08:23:04, 25 Aug. Wire Lan Port 3 up
08:23:03, 25 Aug. System up
08:22:56, 25 Aug. Wire Lan Port 1 up
08:22:55, 25 Aug. Receive a DHCP request
08:22:54, 25 Aug. Receive a DHCP request
08:22:41, 25 Aug. 2.4G WPS feature enabled
08:22:41, 25 Aug. 2.4G WPA2 mode selected
08:22:41, 25 Aug. 2.4G WiFi UP
08:22:41, 25 Aug. 5G WPS feature disabled
08:22:41, 25 Aug. 5G WPA2 mode selected
08:22:41, 25 Aug. 5G WiFi UP
08:22:39, 25 Aug. IPv6 Service: DHCP Server stop
08:22:39, 25 Aug. IPv6 Service: RA Server stop
16:28:49, 22 Aug. Device Disconnected: 192.168.1.157, 1c:9e:46:76:f0:c9, unknown
16:27:41, 22 Aug. Device Disconnected: 192.168.1.231, d0:4d:2c:55:80:19, unknown
16:24:39, 22 Aug. Device Disconnected: 192.168.1.187, d0:4f:7e:84:97:85, unknown
16:20:48, 22 Aug. Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->5030, internal ports: 4500, internal client: 192.168.1.215
16:19:11, 22 Aug. Device Connected: 192.168.1.231, d0:4d:2c:55:80:19, unknown
16:12:26, 22 Aug. Device Connected: 192.168.1.112, d0:03:4b:ea:02:80, unknown
16:09:08, 22 Aug. Device Connected: 192.168.1.157, 1c:9e:46:76:f0:c9, unknown
16:08:50, 22 Aug. Device Connected: 192.168.1.223, 38:c9:86:21:00:35, unknown
16:08:23, 22 Aug. Device Disconnected: 192.168.1.112, d0:03:4b:ea:02:80, unknown
16:08:16, 22 Aug. Wire Lan Port 2 up
16:08:13, 22 Aug. Device Disconnected: 192.168.1.223, 38:c9:86:21:00:35, unknown
16:08:13, 22 Aug. Wire Lan Port 2 down
16:07:56, 22 Aug. Device Disconnected: 192.168.1.188, ac:29:3a:a5:c8:08, unknown
16:07:21, 22 Aug. Device Disconnected: 192.168.1.157, 1c:9e:46:76:f0:c9, unknown
16:07:16, 22 Aug. Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->5356, internal ports: 5353, internal client: 192.168.1.223
16:07:16, 22 Aug. Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->4503, internal ports: 4500, internal client: 192.168.1.223
16:07:14, 22 Aug.
