AaronB
Message 11 of 26
Re: Very slow Connection
It has risen to about 7 before the router resets.
AaronB
Message 12 of 26
Update.
I have left the line connected for 4 days and have not noticed any change in connection speed. I have done the quiet line test in the master socket with a hard wired phone and it sounds really "quiet" no pops, crackling or whining. I have installed a brand new micro filter and there are no other sockets or any other peripherals attached to the socket except the micro filter adsl cable and a telephone. There are still alot of FEC events I have no idea what is causing these although having interleaving on means that these are mostly being corrected. Does anyone have any ideas? Shall l contact a mod and see if i can get my IP profile reset as it seems to be stuck?? I dont want miracles i have had a 2Mbps connection for years and thats was fine but it seemed to have just hit a wall and plummeted through the floor!
Connection Information
Line state:Connected
Connection time:3 days, 20:59:17
Downstream:8.681 Mbps
Upstream:798 Kbps
ADSL Settings
VPI/VCI:0/38
Type: PPPoAModulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.3 dB / 4.9 dB
Line attenuation (Down/Up):37.3 dB / 22.3 dB
Output power (Down/Up):20.3 dBm / 12.8 dBm
FEC Events (Down/Up):118028952 / 374510
CRC Events (Down/Up):89698 / 3291
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1414678 / 10026
Error Seconds (Local/Remote):75236 / 13424
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
 Download  Speed
 417 Kbps
0 Kbps500 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 417 Kbps
 For your connection, the acceptable range of speeds is 100-500 Kbps.
 Additional Information:
 Your DSL Connection Rate :8888 Kbps(DOWN-STREAM), 796 Kbps(UP-STREAM)
 IP Profile for your line is - 500 Kbps
2. Upstream Test:  -provides background information.
 Upload Speed
 623 Kbps
0 Kbps796 Kbps
>Upload speed achieved during the test was - 623 Kbps
 Upstream Rate IP profile on your line is - 796 Kbps
Message 13 of 26
contact the mods http://bt.custhelp.com/app/contact_email/c/4951
it can take and sometimes does take 5 dyas for profile to change but it will probably be that by the time the mods contact you.  if it changes great if not then mods will sort it
AaronB
Message 14 of 26
Oh dear, ohdear. We recieved a phone call today when i was online and thats when it happened! The modem instantly dissconects. I have not noticed this before as we have very little use of the landline. I have unplugged everything but the modem and phoned the landine from a mobile phone and it instantly disconnects again?? But if i make a phone call from the landline it adds massive lattency to the games i'm playing and webpages i'm browsing.This means its nothing my side of the socket? What can cause this problem? Is there anything else i can check??
many thanks .
Message 15 of 26
have you tried another filter and see if that helps.
you can also try disconnecting your phone and then phone your home with mobile and see if it still disconnects - this wll rule out your phone as a problem
AaronB
Message 16 of 26
HAve tried 2 old filters and a brand new one have also tried it with everything unplugged except the router and still it disconnects when i call the land line.....
Message 17 of 26
then as I said before contact the mods for assistance - could be high resistance fault on your line
AaronB
Message 18 of 26
Have been in contact with a mod and he has gone through everything he can so now an engineer is booked for monday. Hopefully this will sort it. But gotta hand it to the mods they were very good a tribute to BT. Also thanks to imjolly for your help in fault finding.
Will get back to you how it turns out.
AaronB
Message 19 of 26
Right here is where i am at now. 2 engineers have visited and they found the line from the exchange to the pole was faulty. They have switched to a new cable and the random disconnects from phone calls have gone and i had a wonderful connection for a day. Now i find that when i leave my modem on for a while  (about 24hrs) the connection has dwindled to a snail's pace (0.5Mb) even tho my sync speed is high and ip profile are high?? I then reset the router and do a speed test and its instantly back up pto a 6.5Mb conection this is the second day in a row since the fix this has happened so this time i have taken the stats before I reset and in 1 hour when i can do it again I will post up the stats for after the reset. Any ideas?
ADSL Line Status
Line state:
Connected
Connection time:
0 days, 21:07:18
Downstream:
8.712 Mbps
Upstream:
784 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.5 Annex A
Latency type:
Fast
6.6 dB / 6.1 dB
37.3 dB / 22.5 dB
20.4 dBm / 12.8 dBm
0 / 34333
1695483 / 24227
0 / 0
0 / 0
0 / 0
1073150 / 205604
57548 / 24226
Download Speed
161 Kbps
0 Kbps
7150 Kbps
Download speed achieved during the test was - 161 Kbps For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Your DSL Connection Rate :8920 Kbps(DOWN-STREAM), 784 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
Upload Speed
605 Kbps
0 Kbps
784 Kbps
>Upload speed achieved during the test was - 605 Kbps
Upstream Rate IP profile on your line is - 784 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
Message 20 of 26
your connection looks good at 8.7mb and your profile should be 7150.  The real problem is your throughput/download which is only 161 instead of about 6500.
you need to contact the mods again for assistance  http://bt.custhelp.com/app/contact_email/c/4951
