AaronB
Message 21 of 26
Re: Very slow Connection
Ok thanks will send off an email and post up the post reset stats in a bit. Just weird as now i have reset the router i'm back to a really fast connection again?
Message 22 of 26
your connection speed and profile were never a problem looking at the stats.  your problem is your throughput not connection speed.  need mods to help get it fixed
check here just in case there are problems with your exhange  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
AaronB
Message 23 of 26
Yeah no problems listed. What I mean is before I reset the router I download files at about 7.5 Kb/s then after about 700-800 Kb/s. Have contacted the mods now see what they say.
Message 24 of 26
better getting it checked out just in case the problem comes back again tomorrow
AaronB
Message 25 of 26
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
 Download  Speed
 5538 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
Download speedachieved
during the test was - 5538 Kbps
For your connection, the acceptable
range of speeds is 2000-7150
Kbps
Additional Information:
Your DSL Connection Rate
:9144 Kbps(DOWN-STREAM), 776 Kbps(UP-STREAM)
IP Profile for
your line is - 7000 Kbps
2. Upstream
 Upload Speed
 590 Kbps
0 Kbps776 Kbps
>Upload speed
achieved during the test was - 590 Kbps
Additional
Information:
Upstream Rate IP profile on your line is - 776
Kbps
We were unable to identify any
performance problem with your service at this time.
It is possible that any
problem you are currently, or had previously experienced may have been caused by
traffic congestion on the Internet or by the server you were accessing
responding slowly.
If you continue to encounter a problem with a specific
server, please contact the administrator of that server in the first instance.
Done this one 1hr 30 mins after reset!
Message 26 of 26
if you can maintain connection at that speed then profile should rise to 8000 due to rise in connection speed  throughput looking ok just now
profile should reset in 3/5 days maybe sooner provided you stay connected 24/7
