Message 1 of 23
Very slow broadband
Earlier this evening i was doing my normal business on internet, whilst webbrowsing the internet got so slow to a point now where it is nearly unusable. Running 2 traceroutes the culprit was soon established. Take a look at the two of them and you will see where they both appear to sharply increase in ms.
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
  1     1 ms     1 ms     1 ms  api.home [192.168.1.254]
  2    99 ms    49 ms    30 ms  esr2.manchester5.broadband.bt.net [217.47.67.141]
  3    30 ms    31 ms    35 ms  217.47.67.77
  4    31 ms    30 ms    29 ms  213.1.69.22
  5    30 ms    31 ms    30 ms  217.32.27.70
  6   208 ms   211 ms   210 ms  217.32.27.182
  7   264 ms   222 ms   222 ms  core2-gig7-0-0.manchester.ukcore.bt.net [109.159.250.218]
  8   243 ms   239 ms   242 ms  core2-te0-3-0-5.ealing.ukcore.bt.net [109.159.250.143]
  9   234 ms   236 ms   233 ms  peer2-xe9-1-0.telehouse.ukcore.bt.net [109.159.254.114]
 10   233 ms   233 ms   234 ms  194.74.65.42
 11     *        *        *     Request timed out.
 12   305 ms     *      233 ms  ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
 13   228 ms   228 ms   228 ms  132.185.254.142
 14   109 ms   115 ms   117 ms  virtual-vip-231.thdo.bbc.co.uk [212.58.241.131]
Trace complete.
Tracing route to google.co.uk [173.194.67.94]
  2    30 ms    29 ms    30 ms  esr2.manchester5.broadband.bt.net [217.47.67.141]
  3    31 ms    31 ms    32 ms  217.47.67.77
  4    29 ms    30 ms    30 ms  213.1.69.22
  5    30 ms    30 ms    32 ms  217.32.27.70
  6     *      218 ms   221 ms  217.32.27.182
  7   179 ms   183 ms   187 ms  109.159.250.226
  8   217 ms     *      231 ms  core1-te0-12-0-4.ilford.ukcore.bt.net [109.159.250.133]
  9   230 ms   231 ms   243 ms  peer1-xe11-0-0.telehouse.ukcore.bt.net [109.159.254.124]
 10   229 ms   227 ms   229 ms  195.99.126.111
 11     *      171 ms   174 ms  209.85.252.188
 12   320 ms   296 ms   304 ms  209.85.253.92
 13     *      235 ms   249 ms  66.249.95.173
 14   232 ms   234 ms   233 ms  209.85.250.167
 15     *        *        *     Request timed out.
 16   219 ms   218 ms   222 ms  wi-in-f94.1e100.net [173.194.67.94]
Trace complete.
Should i make technical support aware of this? Is anyone else having any similar issues and would care to post a traceroute?
Kind Regards,
Ben
22 REPLIES 22
Message 2 of 23
Re: Very slow broadband
i think i might have same issue
playing on tf2 and my ping went from 5 to 200 and is still around 200 now
im based in manchester and my router error logs are showing an ip of bts in manchester as unreachable
FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 192.168.1.65 Dst ip: 46.22.116.233 Type: Destination Unreachable Code: Port Unreacheable
Message 3 of 23
Hi Welcome to the forums
If you post the full stats from your router
For homehub – type 192.168.1.254 into your browser
Navigate to ADSL Settings or use the A-Z at the top right of the home page and scroll down to ADSL Settings and click on it
Click on More Details and then post the full results.
also post the full results from http://speedtester.bt.com/
Have you tried connecting to the test socket at the rear of the master socket Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
also you could try the hints given by poster RogerB in this link they may help http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
Then someone here may be able to help and offer more advice.
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 4 of 23
Horrible ping times tonight also just started about an hour ago.
Starts at hop 7.
Tracing route to www.bt.com [62.239.237.2]
  1    70 ms    97 ms   100 ms  BThomehub.home [192.168.1.254]
  2    29 ms    29 ms    27 ms  213.1.177.186
  3    28 ms    27 ms    27 ms  213.1.176.193
  4    27 ms    29 ms    26 ms  213.1.69.102
  5    26 ms    28 ms    26 ms  217.32.27.58
  6    36 ms    38 ms    39 ms  217.32.27.182
  7   153 ms   142 ms   144 ms  acc2-10GigE-9-2-0.mr.21cn-ipp.bt.net [109.159.250.228]
  8   154 ms   159 ms   159 ms  core1-te0-12-0-4.ilford.ukcore.bt.net [109.159.250.133]
  9   161 ms   164 ms   166 ms  core1-pos7-0.birmingham.ukcore.bt.net [62.6.204.57]
 10   165 ms   162 ms   160 ms  iar1-gig5-4.birmingham.ukcore.bt.net [62.6.196.94]
 11   102 ms   101 ms    99 ms  62.172.57.218
 12     *        *        *     Request timed out.
Message 5 of 23
apart from a known network fault in Edinburgh there are no network problems
Message 6 of 23
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:08:37
Downstream:6.563 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):7.4 dB / 20.0 dB
Line attenuation (Down/Up):32.2 dB / 17.0 dB
Output power (Down/Up):19.8 dBm / 11.9 dBm
FEC Events (Down/Up):2076 / 0
CRC Events (Down/Up):47 / 5
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):54 / 0
Error Seconds (Local/Remote):19 / 1
Message 7 of 23
never noticed but my speed has dropped too
heres my results from speed test
FAQ
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
 Download  Speed
 4032 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 4032 Kbps
 For your connection, the acceptable range of speeds is 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :18531 Kbps(DOWN-STREAM), 1179 Kbps(UP-STREAM)
 IP Profile for your line is - 16349 Kbps
2. Upstream Test:  -provides background information.
 Upload Speed
 913 Kbps
0 Kbps1179 Kbps
>Upload speed achieved during the test was - 913 Kbps
 Upstream Rate IP profile on your line is - 1179 Kbps
Message 8 of 23
here is adsl stats
Line state Connected
Connection time 0 days, 0:11:03
Downstream 18,531 Kbps
Upstream 1,179 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 6.1 dB / 6.3 dB
Line attenuation (Down/Up) 17.0 dB / 8.8 dB
Output power (Down/Up) 0.0 dBm / 12.2 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 4294967264
CRC Errors (Down/Up) 2 / N/A
HEC Errors (Down/Up) N/A / 0
Error Seconds (Local) 2
Message 9 of 23
he only problem i can see is your download speed is low it would be worth running at least 3 Full BT speed-tests over the next 24 hours to see if it shows up any possible exchange problems or possible exchange congestion issues
Message 10 of 23
same problem here it seems. started about half 8, guessing someones dropped a pot of coffee on a router at ealing or telehouse.
