Message 11 of 23
Re: Very slow broadband
This started about an hour ago, Turned off router for 15 minutes. Did a factory reset of router. Changed filters and tried another socket and it made no different. ms is still high when reaching that hop.
Message 12 of 23
ok a couple of taces i did, first up bbc.co.uk from my own pc.
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
  1    56 ms    99 ms    99 ms  BThomehub.home [192.168.1.254]
  2    33 ms    31 ms    30 ms  217.47.204.58
  3    30 ms    29 ms    40 ms  217.47.204.145
  4   221 ms   218 ms   215 ms  213.1.69.98
  5    34 ms    31 ms    31 ms  217.32.27.234
  6    31 ms    31 ms    32 ms  217.32.27.70
  7   205 ms   211 ms   212 ms  217.32.27.182
  8   213 ms   217 ms   217 ms  109.159.250.226
  9   285 ms   297 ms   311 ms  core2-te0-4-0-0.ealing.ukcore.bt.net [109.159.250.131]
 10   294 ms   297 ms   295 ms  peer2-xe9-1-0.telehouse.ukcore.bt.net [109.159.254.114]
 11   272 ms   281 ms   291 ms  194.74.65.42
 12     *        *        *     Request timed out.
 13   218 ms   278 ms   219 ms  ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
 14   223 ms   225 ms   224 ms  132.185.254.142
 15   192 ms   199 ms   202 ms  virtual-vip-231.thdo.bbc.co.uk [212.58.241.131]
Trace complete.
and then using a web based one from the states to 109.152.250.131 ealing.
TraceRoute to 109.152.250.131 [host109-152-250-131.range109-152.btcentralplus.com]
Host name
Hop(ms)(ms)(ms) IP Address
1 5 1 0 206.123.64.154jbdr2.0.dal.colo4.com
2 0 0 0 64.124.196.225xe-4-2-0.er2.dfw2.us.above.net
3 0 0 1 64.125.26.213xe-1-1-0.cr2.dfw2.us.above.net
4 6 5 5 64.125.31.122xe-4-2-0.cr2.iah1.us.above.net
5 6 5 5 64.125.30.65xe-0-0-0.cr1.iah1.us.above.net
6 32 32 33 64.125.25.113xe-2-1-0.cr1.dca2.us.above.net
7 34 33 34 64.125.29.18ge-2-3-0.mpr1.dca2.us.above.net
8 105 105 105 64.125.31.185so-1-1-0.mpr1.lhr2.uk.above.net
9 106 105 105 64.125.27.146xe-0-1-0.mpr1.lhr1.uk.above.net
10 142 106 105 195.66.224.69linx1.ukcore.bt.net
11 106 107 107 62.6.200.157-
12 107 107 107 109.159.249.22acc1-10gige-0-1-0-3.l-far.21cn-ipp.bt.net
13 108 107 107 109.159.249.77-
14 109 107 108 217.41.168.106-
15 107 106 107 217.41.168.42-
16 108 109 107 213.120.177.121-
17 Timed out Timed out Timed out  -
18 Timed out Timed out Timed out  -
19 Timed out Timed out Timed out  -
20 Timed out Timed out Timed out  -
Trace aborted.
so id say its a bt network problem rather than router reset problem unfortunatly.
Message 13 of 23
Message 14 of 23
seems mine is better now
http://www.speedtest.net/result/1743145892.png
ping is still a little high but better than 200
Message 15 of 23
hi can you all post full BT speed tests please
Message 16 of 23
heres mine, ignore the profile as its still a fresh reset from today.
Download speedachieved during the test was - 2589 Kbps
For your connection, the acceptable range of speeds is 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :4512 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3000 Kbps
did one a hour or so agow hen this all started and i was getting a download speed of 1120 !?
but compared to 9 oclock its a lot better than it was but still flakey.
Message 17 of 23
Ping and speed has improved a bit but still isnt as fast as it should be.
Download speedachieved during the test was - 2561 Kbps
Your DSL Connection Rate :6720 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
Message 18 of 23
you look to be suffering from normal peak time slow down across the network
Message 19 of 23
If 400 ms is "normal" I wont be around much longer.
Message 20 of 23
A 55% reduction in speed is not normal, even at these times. My speed would normally be at about 3500 - 4000 Kbps.
