dunners
Message 31 of 44
Re: Very slow download speed after 1 month of 8-9mb Download
Thank you both for the help, I
Will post the stats after 3 days, hoping this will get the speed back up. How would I go about changing the socket - Do you mean a new plate for the master socket? Can BT help with this?
Sam Dunning
Message 32 of 44
a new faceplate for the master if needed can be done by you without BT but need to see what connection like now in test socket and after banding released.
did you discover what the 2 wires were for that came from the master?  is that a broken splitter in the socket where you can see the wires?
dunners
Message 33 of 44
How do I tell if a new faceplate is needed?
I will post the stats after 3 days, cheers.
One wire goes upstairs to a phone socket. I was using this phone socket before.
The other goes to an extension cable that can plug into the back of a router I believe?
Message 34 of 44
you will know if the faceplates faulty if the connection speed differs between the test socket and the faceplate you need to tidy up the wiring you may be able to remove the extension cable you mention if it is not in use
dunners
Message 35 of 44
OK, thank you. I will wait to see if the results improve after the 3 days.
Cheers
Message 36 of 44
ok please do keep us posted
dunners
Message 37 of 44
Hi,
Here is the BT speed test after 3 days of using the test socket in the master connection. Nothing seems to have improved?!
1. Best Effort Test:  -provides background information.
 Download  Speed
 1.84 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.84 Mbps
 For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
 IP Profile for your line is - 2 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.86 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.86Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
dunners
Message 38 of 44
Here are the hub stats after the 3 days:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 23:20:07
Downstream:2.216 Mbps
Upstream:1.09 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):23.6 dB / 6.4 dB
Line attenuation (Down/Up):34.4 dB / 18.5 dB
Output power (Down/Up):18.0 dBm / 12.1 dBm
FEC Events (Down/Up):1130 / 321
CRC Events (Down/Up):0 / 82
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 99
Error Seconds (Local/Remote):0 / 25
Message 39 of 44
You are still only showing a 23 hour connection time you have to get to 3 days before any thing can be done with the noise margin
dunners
Message 40 of 44
It was left for 3 days - However the cable was tripped on and the router went on and off. This must has reset the timer. I will leave it again for 3 days and post the stats.
Cheers
