dunners
Message 1 of 44
Very slow download speed after 1 month of 8-9mb Download
Hi,
We have moved address in the last 2 months, until the past few days the BT broadband has been quite decent considering this town generally seems to have poor internet speeds. (8-9 meg download and 0.8 - 0.9 meg upload). However for the past week our download speed has dropped to around 1-2mb and the upload speed is the same. We are also getting a lot of disconnects. Please help and advise - I am cabled into the router and have a high spec PC (using BT unlimited broadband, the best package and mainly using broadband for gaming, hence why this is very frustrating. Also any ideas why this should happen now, rather than when we just moved into the address?! Further details available upon request.
Thanks in advance
Sam
43 REPLIES 43
Message 2 of 44
Re: Very slow download speed after 1 month of 8-9mb Download
Hi Welcome to the forums
Here are some help pages done by CL Keith http://forumhelp.dyndns.org/speed/Speed.html
also post your full hub stats by entering 192.168.1.254 into your web browser address bar and navigate to adsl or use a-z, if netgear enter 192.168.0.1
Can you also post the full results from BT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket    Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
dunners
Message 3 of 44
ADSL Line Status
Connection Information
Line state:Connected
Connection time:1 days, 11:21:54
Downstream:2.216 Mbps
Upstream:1.111 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):22.0 dB / 5.4 dB
Line attenuation (Down/Up):34.6 dB / 18.7 dB
Output power (Down/Up):18.0 dBm / 12.6 dBm
FEC Events (Down/Up):2490 / 1425
CRC Events (Down/Up):0 / 592
dunners
Message 4 of 44
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 1.85 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.85 Mbps
 For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
 IP Profile for your line is - 2 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.83 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.83Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Message 5 of 44
can you please connect your hub to the test socket and repost the hub stats again please your connection speed is very low you should be getting around 12mb your noise margin is very high showing you have a noise problem causing a number of disconnections
dunners
Message 6 of 44
I just tried the quiet line test and there was no sound.
This problem is verty unsualy because as mentioned for the past month atleast the inernet has been at an ok donwload speed.
Please advise,
Sam Dunning
Message 7 of 44
could you please try the test socket please and post back the hub stats when connected there
dunners
Message 8 of 44
I am unable to connect the hub to the main phone socket, currently it is conntected to a socket upstairs, see this image of the main phone socket  for why -
http://i53.photobucket.com/albums/g41/3dsk8ers/Mainphonesocket.jpg
Any ideas please?!
Sam Dunning
Message 9 of 44
i am suspecting an internal wiring problem and the results from the test socket is the only way of telling if you had to call an engineer out and no fault was found at the test socket it would be a chargeable visit and could cost you 130.00
Message 10 of 44
could you also post the additional hub stats by clicking on the show more details
