dunners
Message 21 of 44
Re: Very slow download speed after 1 month of 8-9mb Download
OK, thank you I will do it in the next hour.
Sam Dunning
dunners
Message 22 of 44
I have cremoved the front plate from the master socket and connected to the test socket and here are the results (I had to use my fathers PC on wirelss as the cable isnt long enough for my pc)
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 1.89 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.89 Mbps
 For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
 IP Profile for your line is - 2 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.86 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.86Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
Message 23 of 44
we really need the hub stats as well please
dunners
Message 24 of 44
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:20:54
Downstream:2.216 Mbps
Upstream:1.08 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):23.1 dB / 5.9 dB
Line attenuation (Down/Up):34.4 dB / 18.5 dB
Output power (Down/Up):18.0 dBm / 12.6 dBm
FEC Events (Down/Up):0 / 35
CRC Events (Down/Up):0 / 33
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 22
Error Seconds (Local/Remote):0 / 0
Message 25 of 44
hi yes you are in a banded profile as imjolly has said you now need 3days stable connection for the banding to lift automatically
dunners
Message 26 of 44
Managed to run the test on my too (cable was long enough)
Here are the speedtest results with router plugged into test socket:
FAQ
 Download  Speed
 1.82 Mbps
0 Mbps2 Mbps
 Download speedachieved during the test was - 1.82 Mbps
 Upload Speed
 0.87 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.87Mbps
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
dunners
Message 27 of 44
So I need to leave the router plugged into the test socket for the next 3 days?!
dunners
Message 28 of 44
Again for my pc (cabled not wireless)
Do I need to leave the router plugged into the test socket for the next 3 days to get the speed back up to 8-9mb?!
ADSL Line Status
Connection time:0 days, 00:29:25
Upstream:1.08 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Message 29 of 44
Hi yes you need 3days stable connection then please post back the hub stats and a speedtest we can then advise further if needed
Message 30 of 44
I would leave in the test socket for the 3+ days and maybe think of improving your sockets.  with your attenuation I would expect a connection speed of about 11/12mb on a good connection
