Minimix
Message 1 of 23
Very slow download speeds on Desktop
I've Had bt Infinity for nearly 3 weeks and for the laptops they always run between 15-37mb/s however my desktop pc is running at 0.5mb/s and I've tried searching online for ways to fix it, any advice on what computer settings I may need to change
Tags (3)
22 REPLIES 22
mitchy
Message 2 of 23
Re: Very slow download speeds on Desktop
My connection has dropped today aswell, not getting pass 6mb
Distinguished Expert
Message 3 of 23
Is that wired or wifi ?
Message 4 of 23
Is that wired or wifi?
mitchy
Message 5 of 23
Wired, i usually get around 37mb but after a restart of the modem the speed is getting worst, down to 3mb now
Message 6 of 23
What does the BT speedtester say your IP Profile is?
Minimix
Message 7 of 23
wireless
mitchy
Message 8 of 23
38000kp
Minimix
Message 9 of 23
thing is in my house we have 3 laptops and 2 pc's on all 3 laptops they range from 20-37 mb/s and on one of the pc's it also goes up to 37mb/s however one of the pc's goes a max of 0.5mb/s. When we called bt they said it may be becasue of the distance but my laptop was in the same room and it ran at 30mb/s. I have no idea why the pc is running so slow
Message 10 of 23
It must be something to do with that computer. Try disabling the firewall?
Or it could have a knackered network card/wireless adaptor.
