Newbie
Message 1 of 4
Very slow infinity
I was getting 6.5-8mb/s on regular broadband and recently had an 'upgrade' to infinity. I am now getting 2.19mb/s on infinity.
I am 1.74km from the exchange so potentially upwards of 2km if it snakes a lot. I'm one of several houses 1/2 mile away from a large village, 4 mile from a large city.
How bad would the copper need to be to get such low speeds? Is there anything I could do to try and improve the speeds wthout getting an engineer involved?
3 REPLIES 3
Message 2 of 4
Re: Very slow infinity
fibre is based on distance from the street cabinet and distance from exchange is immaterial to your connection speed
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
Newbie
Message 3 of 4
Thanks for quick response!
After running diagnostics a fault was found outside my home; will wait on that now.
Results from ADSL Checker below
VDSL Range A (Clean)7.82.71.20.8--Available----
VDSL Range B (Impacted)5.321.10.6--Available----
WBC ADSL 2+Up to 11.5--10 to 13Available----
WBC ADSL 2+ Annex MUp to 11.5Up to 110 to 13Available----
ADSL MaxUp to 8--7 to 8Available----
WBC Fixed Rate----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Message 4 of 4
With dslchecker results it would appear that you can get a better connection speed on adsl2/2+ than you can by moving to faster broadband
