Message 1 of 2
Viewing ir downloading JPG files
Does anybody have the solution to the following problem?
I cannot download or view JPG files on my bt wireless connection unless I disconnect my phone/ipad and use my 4g connection provided by my mobile provider. I can use other wireless broadband services on these devices but not my own at home.
Please can anyone help me.
1 REPLY 1
Message 2 of 2
Re: Viewing ir downloading JPG files
Check to see if BT Web Protect is turned on and if it is try turning it off.
https://www.bt.com/help/security/set-up-and-use-bt-web-protect#:~:text=You%20can%20turn%20off%20BT,y...
