rosanna49
Newbie
Message 1 of 3
Virus
My laptop has 2 viruses that Mcfee cant get rid of...I have spoken to them and they told me to contact you to fix it.
Can you help ASAP please
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Virus
Hi. Welcome to the forums.
McAfee have said to contact whom ? Did it say what it might think the viruses are ? And can you say what symptoms you are seeing ?
May I suggest that you go to :-
http://windows.microsoft.com/en-US/windows/products/security-essentials
and try to install MSE - it's got a very good name. Hopefully any virus you've got won't interfere with the installation.
Distinguished Guru
Distinguished Guru
Message 3 of 3
Re: Virus
In my experience that's excellent advice. But if you keep MSE make sure you uninstall McAfee and run the McAfee clean-up tool. Having more than one antivirus running can mess your computer.
