willc01
Message 1 of 4
Vision+ & Youview together
I signed up to infinty and Vision last September. BT are upgrading me to Youview on 21/01/13.  Can i still use both boxes as i have a lot of Freeview programmes recorded.  Im not worried about freeview or on demand content just what i have recorded from freeview that may take a few months to watch?
Im assuming i can keep the vision box or will they want it back?
3 REPLIES 3
TimSmedley
Message 2 of 4
Re: Vision+ & Youview together
Hi
Yes you can use both; we are doing just that with the old black box. It all works as before except the ESPN card doesn't work (which I didn't expect it to) as this is not part of the YouView package.
BT recently mentioned they are considering a formal multi-room option so the Visions Boxes may get chopped at that point but I suspect that will be many moons away!
Regards
Tim
willc01
Message 3 of 4
Thanks Tim but does the old box need to be connected to the router and does freeview work on it if it isnt?
TimSmedley
Message 4 of 4
Hi
We are running both at the same time connected to the HH3.
To be honest I didnt try without but the Vision Box doesnt normally work without a Broadband connection and you certainly dont get the programme guide.
Tim
