yep
Message 1 of 2
Vonage box not work unless Smarthub firewall disabled.
I have just joined BT broadband and my vonage viop box will not work unless I disable the firewall in the Smarthub. Any fix or workaround?
1 REPLY 1
Liam_
Recognised Expert
Message 2 of 2
Re: Vonage box not work unless Smarthub firewall disabled.
@yep
I would imagine you have to forward the correct ports in the router.  Have a look here:-
https://support.vonage.co.uk/articles/answer/Port-Forwarding-454
