Old_Welsh_dragon
Message 1 of 3
Vonets VAP11G WiFi Bridge not finding network HH5 type B
I had a new BT Home hub 5 (type b) to replace my Hub 5 (type a) that packed in.
I'm trying to set up the Vonets VAP11G WiFi Bridge on the new hub but it doesn't find my network, it finds others on the street that are close. It worked fine with the old hub.
Can anyone help.
2 REPLIES 2
gg30340
Message 2 of 3
Re: Vonets VAP11G WiFi Bridge not finding network HH5 type B
If there is a way to do a factory reset of the Vonets you should do that. That will wipe any residual settings left over from the "old" Homehub5. Once you have cleared all the settings try setting it up again as though it is a first time install.
See link for instructions
http://vonets.es/download/VAP11G%20-%20WiFi%20Bridge%20User%20Manual.pdf
Old_Welsh_dragon
Message 3 of 3
Thanks, all sorted now, swapped to another usb port to set up and it worked fine, must have a dodgy port.
