hamish72
Recognised Expert
Message 201 of 202
Re: CONSIDER THIS FORUM FEED CLOSED
I was responding to a question not looking for an answer Smiley Happy
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Community Manager - Retired
Message 202 of 202
Morning All
As a few have mentioned on this thread the usage monitor is now live!
To see your broadband usage you have to be logged into 'My BT' to view the monitor.  The broadband line you want to check also has to be on the same account.  If you haven't yet registered to view your bills online, you can do this now via http://www.bt.com/mybt.
As suggested by some members I am going to close this thread now as it has covered a couple of different topics.  Please feel free to start a new thread if you have any comments on the new usage monitor, this will make it easier for all to see in one clear thread.
Thx
Kerry
Retired BTCare Community Manager - StephanieG and SeanD are your new Community Managers
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
