djh22
Recognised Expert
Message 181 of 202
Re: WHERE IS OUR USAGE MONITOR BT
Where ? I can't see it on my account.
What do you think about it , is it OK ?
djh22
Recognised Expert
Message 182 of 202
Yes it is there, not sure if it's meant to be tho' as Kerry hasn't said anything yet.
Distinguished Guru
Message 183 of 202
-+-No longer a forum member-+-
captain666
Message 184 of 202
Once you log into your BT.com account, go to your account/s.  There should be a section at the bottom for manage your services.  I've got 2 tabs there Landline and Broadband.  Click on broadband and you should then see in the foloowing (hopefully)
Jusr click on the link for view your broadband usage.  It does give a simple display of how much you've used.  It does seem only to have the details of what has been used up to 23:59 last night
Message 185 of 202
CONSIDER THIS FORUM FEED CLOSED
So,
BT have now introduced the Usage Monitor, FINALLY!
I have asked Kerry to close this forum off, please feel free to comment on new feeds.
CG
CG Over An Out
djh22
Recognised Expert
Message 186 of 202
Re: CONSIDER THIS FORUM FEED CLOSED
@ComputerGeek wrote:
So,
CG
Fair call CG.
Distinguished Guru
Message 187 of 202
This item was actually there last week, but did not work. When I pressed it - it looked like it was only for the folk on the "pay for extra" usage.
However, the display for the phone number is completely the wrong format for "non" 02x numbers. It's in :-
3 4 4
notation.
This needs correcting. It almost seems like the people designing the display are in London or another of the 02x type number ranges.
Montala
Message 188 of 202
Thanks to all concerned.
One last quick question though... can we consider that the information given started on 1st October?
That is to say, will it correctly measure the total usage for the whole of this month?
Thanks!
djh22
Recognised Expert
Message 189 of 202
Thanks!
I keep a spreadsheet of my usage and yea the usage quoted on the monitor is from 1st of October in my case anyway.
Montala
Message 190 of 202
That sounds encouraging... thanks for the fast reply, as I can see this thread being closed very quickly now!
