hamish72
Recognised Expert
Message 191 of 202
Re: CONSIDER THIS FORUM FEED CLOSED
My onboard monitor says I have used 2.4 Gig to date this month BT,s says 1.2 Gig so I think the answer to your question is no
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
djh22
Recognised Expert
Message 192 of 202
Re: WHERE IS OUR USAGE MONITOR BT
@Andy_N wrote:
@djh22 wrote:
Yes it is there, not sure if it's meant to be tho' as Kerry hasn't said anything yet.
This item was actually there last week, but did not work. When I pressed it - it looked like it was only for the folk on the "pay for extra" usage.
However, the display for the phone number is completely the wrong format for "non" 02x numbers. It's in :-
3 4 4
notation.
This needs correcting. It almost seems like the people designing the display are in London or another of the 02x type number ranges.
It's quoting my number correctly, just that there's to many spaces.
Message 193 of 202
3 4 4
notation.
Suggest new Feed please!
CG Over An Out
Message 194 of 202
@Montala wrote:
Thanks to all concerned.
One last quick question though... can we consider that the information given started on 1st October?
That is to say, will it correctly measure the total usage for the whole of this month?
Thanks!
Yes, it is the first of each actual month e.g. 1st October, 1st November and so on 😉
CG Over An Out
Distinguished Guru
Message 195 of 202
Don't forget, the monitor is showing up until a certain date/time. Mine shows up until yesterday midnight.
hamish72
Recognised Expert
Message 196 of 202
Yes but today I used 400 Meg so it still dont add up still around 0.8Gig down
djh22
Recognised Expert
Message 197 of 202
Would it be better to start a new thread on the usage monitor ? I can see there's going to a lot of posts about it.
Del.
Message 198 of 202
I think you need to raise a new feed with a question on how the usage monitor now works, i can see it works on a day by day basis.
If you have any queries i would recommend calling  BT on 0800 111 4567
cg
CG Over An Out
djh22
Recognised Expert
Message 199 of 202
Snap.
Message 200 of 202
Del.
TOTALLY AGREE!!!
I ahve asked Kerry to close this feed, 😉
CG Over An Out
