Message 11 of 23
Re: WHY BT..is my line slow...again
Are you using wireless or Wired? You'd be surprised at the difference in throughput speed that can sometimes be seen using the two different connection types.
Message 12 of 23
hi can you please post the following attenuation db up/down noise margin up/down that you can see on your modem (router)as these will help us more
Message 13 of 23
type this in your browser address bar http://192.168.0.1 you should find the need stats within the set up pages
Message 14 of 23
The noise margins will have nothing to do with his throughput. The sync speeds are fine, it's the throughput he's unhappy with. Can you run a speedtest using an Ethernet connection if you're not already and post up the results.
Message 15 of 23
Sorry didn't see your earlier post where you mentioned everything is wired. When you've ran the test was it the only thing that was connected to the network at the time?
As it goes the throughput you're getting is well within the acceptable range for your line so BT Wholesale wouldn't accept it as a valid fault and therefore no network investigation would be done.
Message 16 of 23
Without a series of speedtest over a 24hour period you cannot say that exchange congestion is not a problem the speedtest are needed to prove congestion or some otherproblem
Darren
Message 17 of 23
Morning Guys,thanks for your responses,I cannot connect to my modem UI,god knows why,I have to normally unplug ethernet
FAQ
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
 Download  Speed
 7640 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 7640 Kbps
 For your connection, the acceptable range of speeds is 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :20775 Kbps(DOWN-STREAM), 1279 Kbps(UP-STREAM)
 IP Profile for your line is - 18329 Kbps
2. Upstream Test:  -provides background information.
 Upload Speed
 935 Kbps
0 Kbps1279 Kbps
>Upload speed achieved during the test was - 935 Kbps
 Upstream Rate IP profile on your line is - 1279 Kbps
from router to do this,,,but its not working so cant get the stats......
Anyway this is what I get this morning...............GREAT......NOT
Message 18 of 23
Hi your speed tests do indicate a problem although I would not expect congestion at this time of day there could be some other exchange problem causing you low throughput
I suggest you contact the forum mods on this link and ask them to investigate your connection http://bt.custhelp.com/app/contact_email/c/4951 they are a small team ofuk based Bt Specialists who will normally contact you witin 72 hours either by phone or email personally they have a great record for getting problems resolved
Darren
Message 19 of 23
thanks john,india are running a line check at the moment,not that they can do much as usual
Message 20 of 23
Hi dArren if you contact the mods please try and avoid using the help line as well as it only causes confusion the mods will get things sorted just deal with them theywill get things sorted for you
