atttim
Message 1 of 9
WILL I GET ANY BT SPORT CHANNELS
I have BT Vision Essentials Package, Black Box Latest Upgrade.
No cards, and its not a Youview Box  and I don't have Infinity.
Will I get any of the following.....BT Sport, BT Sport 1 or BT Sport 2 as it stands ??
8 REPLIES 8
guilbo
Guru
Message 2 of 9
Re: WILL I GET ANY BT SPORT CHANNELS
If you don't have a YouView box and broadband from BT you should be able to buy a viewing card to give you access to BTS 1 and 2.
munko123
Message 3 of 9
Its a minefielf check your local transmitter it can be down do that.
guilbo
Guru
Message 4 of 9
True, you need to be able to receive the Com6 mux. If you can get 4music and ITV4 the transmitter should be OK.
atttim
Message 5 of 9
Yes I do have my broadband with BT but not Infinity.
Yes I do get 4Music and ITV4
So where do I stand now...??
atttim
Message 6 of 9
Cancel my last.....just retuned my box.....I am now getting BT Sport but NOT BT Sport 1 & 2 which I assume means I will have to buy a card or is that only if I have Youview ??
guilbo
Guru
Message 7 of 9
When you say you're not getting 58 and 59 do you mean they're not in the guide. They should be even if you've not got a card. If they're not, check the channel management menu to see if they're disabled. If they're not there either, I'm stumped I'm afraid.
A card is needed to access the channels on a Vbox, but a YouView box doesn't have a card slot so there's no way to view them.
atttim
Message 8 of 9
Yes 58 & 59 are in the guide .....and after my retune it tells me to insert a card for these channels.
Problem solved !
guilbo
Guru
Message 9 of 9
Good oh. Now all you've got to do is talk to support and get them to send you a card in the week that everybody, their dogs and their budgies are going to be talking to them about the new toy. Best of luck Smiley Very Happy. Let us know how you get on.
