Message 1 of 9
WIRING COLOURS ON A EXTENSION WIRE
Hi all, I have run a telephone extension wire through my wall and to keep the hole small I have cut the plug off one end.
I had the intention to put a wall socket on but  I am stuck on how to wire it up as the coluors are not as expected.
The wiring instrutions that came with the socket state that it should be wired as :
NO 1 GREEN/WHITE RING
NO 2 BLUE/WHITE RING
NO 3 ORANGE/WHITE RING
NO 4 WHITE/ORANGE RING
NO 5 WHITE/BLUE RING
NO 6 WHITE/GREEN RING
I only have : RED
                  BLACK
                  GREEN
                  YELLOW
Cleary I have used the wrong wire and  It's too late to change it now.
Can anyone please tell me what colours go to what numbers?
Thanks Paul
8 REPLIES 8
Message 2 of 9
Re: WIRING COLOURS ON A EXTENSION WIRE
As electrons aren't particularly fussy about the colour of the insulation connect the same numbers at each end with the same colour wire. Only connections 2 & 5 are required.
Message 3 of 9
Thanks but the other end has got a plug on it so I'm still none the wiser.
If I just try all the colours till I get a ring tone is there any possibility I will damage the phone or line itself?
Message 4 of 9
No, just try all permutations of 2 wires, polarity doesn't matter so only 6 possibilities to try.
Message 5 of 9
Great, I know that it's not the best wire but will my router also work off just the two wires?
Message 6 of 9
Phones and broadband only use 2 wires. There are only 2 wires from your house to the cabinet/exchange.
Message 7 of 9
Great stuff! Thanks I'll let you know how I get on.
Message 8 of 9
Success. I connected the yellow to number two and the black to number 5.
Phone and Internet both working fine.
Thanks for the help.
Message 9 of 9
Thanks for reporting back, glad to hear you got it working.
