mellorij
Message 1 of 5
WPA / WPA 2 Connection issues
Like others on this board, I have been having issues connecting to my Home Hub3 using WPA / WPA2. WEP is fine.
However I have noticed that my firmware is only V100R001C01B031SP09_L_B which I believe to be out of date.
I was wondering if a frimware update would help?
Could one of the moderators arrange this?
Ian
4 REPLIES 4
john46
Message 2 of 5
Re: WPA / WPA 2 Connection issues
hub firmware upgrades are rolled out automatically all that is needed for the hub to be turned on 24/7 for it to receive the latest upgrade
mellorij
Message 3 of 5
John,
Yes I am aware of that, but for some reason mine is not updating. I suspect it is because I was previously part of a trial and the update flag has not been switched back on.
Ian
gg30340
Message 4 of 5
Try a factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 seconds. Once it has reset leave it switched on 24/7.
mellorij
Message 5 of 5
OK, I'll reset and let you know what happens.
