megabyting
Message 1 of 18
Want faster speed
Hi
I am currently getting 9mb.  I did a diagnostic test through BTWholesale website and it says max speed my line can get is 21mb and want to know is it possible to get that kind of speed.
I can't get fiber in my area (probably not in my lifetime)
17 REPLIES 17
imjolly
Message 2 of 18
Re: Want faster speed
 Sorry but that does not mean you can get 21mb - it is standard regardless of your actual connection speed
enter your phone number and post results. Remember to delete number.
john46
Message 3 of 18
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
imjolly
Message 4 of 18
Can you also post the stats from your router please
are you using test socket with new filter?
megabyting
Message 5 of 18
Thanks for replying
1. Best Effort Test: -provides background information.
Download Speed
8.19 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 8.19 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 9.61 Mbps
2. Upstream Test: -provides background information.
Upload Speed
0.94 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.94Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
imjolly
Message 6 of 18
I couldn't get link to work but john46 has posted it. This will show what possibilities there is for your line
megabyting
Message 7 of 18
I am using TP-Link AC1900
DSL
Line Status:
DSL Modulation Type:
Annex Type:
  Upstream Downstream
Current Rate(kbps)116710892
Max Rate(kbps)116410960
SNR Margin(dB)5.86
Line Attenuation(dB)21.237.5
Errors(pkts)7661
imjolly
Message 8 of 18
 From the checker estimate you could get about 15mb. Are you using the test socket with a new filter especially if you have extension sockets in other rooms
megabyting
Message 9 of 18
Thanks for your help guys.  I was getting mixed messages from BT.  Sales people say I can get faster speed and tech say I can get max 6mb.   9mb not bad but faster would be nice.
Regards,
Ali
megabyting
Message 10 of 18
@imjolly everything is new and I did try to connect to the test socket and there isn't one. Line was installed by kelly communications not Openreach. I have a feeling they did dodgy work.
