Message 1 of 3
Weak Wi-Fi signal
I just upgraded from BT superfast unlimited to Fibre 1, but still got original BT Router.  Do I need that upgrading too?  Wi-Fi much better downstairs, but still slow in back bedroom.  I read can boost Router Wi-Fi output signal by fitting a high gain antenna to Router.  However, I cannot see existing antenna or where to fit a new one.  They all seem to have a screw connection that I cannot find on Router,
2 REPLIES 2
Message 2 of 3
Re: Weak Wi-Fi signal
@AndyBuck25
None of the home hubs have external aerials, or a means of plugging one in.
If you just need a better wifi signal in the back bedroom, then this is probably the best solution.
https://shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
It also give you two Ethernet ports as well.
Message 3 of 3
