jaga28
Message 1 of 3
Web Protect and Virus Protect and existing Antivirus software
Just connected with Infinity and trying to understand the "extras" that are part of my package. Will activating Web Protect and/or Virus Protect cause problems with my existing anti virus programme (Avast) ? Will i have to either uninstall Avast or decide not to activate Web Ptotect and Virus Protect? Also, how do i de-activate Parental Controls as it is already shown as being activated?
2 REPLIES 2
gg30340
Message 2 of 3
Re: Web Protect and Virus Protect and existing Antivirus software
You can only have one antivirus running on a computer. I would stick with Avast and not install BT/McAfee Virus Protect.
You can have web protect running at the same time as that is not installed on your computer. see link
http://bt.custhelp.com/app/answers/detail/a_id/54056/~/learn-about-bt-web-protect
You should be able to deactivate parental controls in the My Extras section of your MyBT
http://bt.custhelp.com/app/answers/detail/a_id/55707/~/turning-off-bt-parental-controls-and-bt-prote...
jaga28
Message 3 of 3
thank you very much for your quick and helpful reply
