walkerx
Recognised Expert
Message 1 of 3
Webpage issues - anything happening?
Just noticing tonight that there seems to be a problem with accessing .com websites
ie www.google.com www.bt.com community.bt.com uk.msn.com
but can access .co.uk addresses fine
anyone else noticing this
2 REPLIES 2
Moderator-Retired
Message 2 of 3
Re: Webpage issues - anything happening?
Hi walkerx,
Are you still having trouble with this or has it cleared up?
Chris
BT Mod Team
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
walkerx
Recognised Expert
Message 3 of 3
Hi ChristoperP,
I changed to google DNS on pc which has resolved this.
I will monitor to see if it re-occurs
